Go Back   Boatfreaks > General Forums > Insurance and Finance
Register Calendar Mark Forums Read
Old 04-15-2009, 06:40 PM
insurancegoddess's Avatar
insurancegoddess insurancegoddess is offline
Boatfreaks Advertiser
Awesome "niche" Insurance Program
I have a performance program that is saving boaters up to 50% off their current rates, even if already insured through their home/auto companies. If you fit the niche, then this program rocks and could save you a quite a bit off your current rate.
For example, just quoted a 2002 34 Powerquest Valued at $98,000 Their current insurance rate: $1678 - Our quoted rate: $953 per year with a policy with no lay up and no restrictions on state by state use.
So, here is the niche that I’ve discovered thus far…
Hull Type: V-Hull boats ONLY
Age of Boat: 1990 model and newer (any boat 27ft and 10 years and older (not including 1999 models will require a survey to bind coverage)
Length: 18ft – 42 ft
Engine: Max 700 HP per engine. Max two total I/O engines, 3 max if outboard
HERE IS THE KICKER THAT MAKES THIS PROGRAM WORTH IT… GREAT DISCOUNT!!!!
Boat must be moored in one of the following states: AZ, AR, CA, CO, ID, IL, IN, IA, KS, KY, MI, MN, MO, NE, NV, NH, NY, OH, OK, PA, TN, UT, VT, WV, WI
This program is AWESOME!!!!! The rating is great and it is for all boat types. Take 5 minutes and request a quote regardless of when you are up for renewal. Most policies allow you to cancel at any time. We will simply rate you and email you a quote. Thank you and hope to hear from everyone.
OBTAIN A QUOTE BY COMPLETING THIS FORM:
http://www.wakezoneinsurance.com/Quote_form.html
I will post some examples of recent policies before/after that were placed in this program tomorrow.
Stacy Shute (Hanlon)
The NO LIMITS Insurance Agency
866-728-9757 ext 101
Wake Zone Marine Insurance Brokerage, Inc. - CA License 0H05075
For an online quote: www.wakezoneinsurance.com
stacy@wakezoneinsurance.com
Thread Tools
Display Modes
[IMG] code is Off
Copyright ©2000 - 2018, vBulletin Solutions Inc.
