Go Back   Boatfreaks > General Forums > Boatfreaks On-Road
  #16
Old 04-07-2019, 09:38 AM
cfm's Avatar
cfm cfm is offline
Registered Member
Posts: minus 1
Originally Posted by ShopSurfer View Post
Yes it is. Gen 3 LQ9 6.0. 100% stock longblock as of now. I really dont understand his tactics as far as prioritizing the parts needed. Tho i am sure the engine will outlast the transmission, transfer case, cv axles etc etc.
That's most customers with cars/trucks/boats.
Even mention parts that should be replaced also with the new power and it's either 'I'll drive it easy for now' or a "what do you mean?"
"Nothing is done so poorly that the government canít do it worse!"
If the women don't find you handsome, they should at least find you handy.
Sometimes it can be difficult to shake off the shit you read on the internet
Be careful, I think a lot of people on this forum started as retards and got worse. - MMarsha
The Following User likes cfm Post:
  #17
Old 04-07-2019, 09:52 AM
ShopSurfer's Avatar
ShopSurfer ShopSurfer is offline
Originally Posted by Sutphen30 View Post
turbos seem a little big,,maybe he's planning on a stroker w/ more camshaft.
Yes they are. Wayyy too big. Its got a full on valvetrain upgrade waiting to go in. And a LJMS Turbo grind cam. I dont see those turbos being on very long. I hope not anyway
1996 Baja 252 - Carb'd BBC
1992 Mustang - Turbo LS
Need more toys to turbo
  #18
Old 04-07-2019, 09:54 AM
ShopSurfer's Avatar
Call those, "return customers"
The Following User likes ShopSurfer Post:
  #19
Old 04-30-2019, 05:11 PM
Sutphen30's Avatar
Sutphen30 Sutphen30 is offline
Charter Member
any more pics?
I like my food with ketchup.
  #20
Old 04-30-2019, 07:39 PM
ShopSurfer's Avatar
any more pics?
Yes, i got a few on my camera. Ill give yall an update tonight.
The Following 2 Users Like ShopSurfer Post:
  #21
Old 05-18-2019, 02:36 AM
ShopSurfer's Avatar
Tonight, two weeks later... same thing?
Sorry about the delay.
Wastegates plumbed and in place. Fitted and fused it all up on the mock up LS block i have on the stand.
I think they turned out ok
  #22
Old 05-18-2019, 02:59 AM
ShopSurfer's Avatar
back into the truck with the hot parts and turbos, make some over-engineered brackets to get the intercooler mounted
Make some pie cuts for getting a tighter radius than the mandrel bends
Shorten a couple 90 degrees bends for the intercooler inlets
Little rusty on A/C current welding aluminum, but am getting a better understanding of the a/c pulse feature and it is soooo nice to have once you get settings dialed in.
  #23
Old 05-18-2019, 03:07 AM
ShopSurfer's Avatar
This was where the pie cuts were a must. As said before it is a tight fit but everything has good clearance. the passenger side is finished other than needing to roll beads on the coupler joint that sits in the radiator support and welding up the downpipe
The Following 4 Users Like ShopSurfer Post:
  #24
Old 05-18-2019, 07:31 AM
Sutphen30's Avatar
Charter Member
lookin great.
The Following User likes Sutphen30 Post:
  #25
Old 05-19-2019, 09:26 AM
ShopSurfer's Avatar
lookin great.
Thanks!
  #26
Old 06-15-2019, 06:46 AM
ShopSurfer's Avatar
Fab work
Well my part is done with this truc
Sent from my SM-G950U using Tapatalk
Copyright ©2000 - 2019, vBulletin Solutions Inc.
