#91
travis
what is the size of those tires?are the load range E also?
livin the dream,a mans horror story. |
#92
Wow you guys have some heavy duty towing rigs.
Here is my 2003 Chevy Avalanche Z71 4x4
"There are only two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle." Albert Einstein (1879-1955) |
#93
Nobody gives you power. Real power is something you take. I fix things till they can't be fixed Ski Doo Snowmobiles Financial Planning |
#94
Made the Excusion shrink
#95
Nothing Special.....
Powerstroked with the local boy's Edge chip in her for the mountain terrain around these parts.
#96
F-350 PSD Crew Cab 4X4
#97
Not Much compared to some of the others, BUT I had to step up from the last tow vehicle!!!!!!!!
2001 Z-71 5.3 Vortec |
#98
Before I wrecked the old one!!!!
Dont laugh too hard, its all I had left after the divorce, so I had to make it work. |
#99
except when going up the smoky mountains:D :D then the drive train gets a workout
#100
I still got 11 to 12 mpg through the mountains.
#101
Mine pulled the mountains good, It was just a lot of work making sure the transmission didn't do 100 shifts up the hill. In hind sight, I probably should have put it is second gear, and climbed it that way. The Mountain went from 900 feet to 2900 feet in about 5 or 6 miles. Its the only time I have ever seen my water Temp gauge move, and it went from around 200 to 235. Don't have a trans temp gauge, but I'm sure it was hot.
#102
Zone 5,
Don't you have the tow haul feature? I use it all of the time. Chevy reccomends it as well. It holds your gears on starts & while pulling a grade. Like I said earlier, I pulled the smokey mountains and only dropped 1 gear which added 1000rpm. I ran between 75 and 85 mph the whole time. In fact whenever some jerk pulled out in front of me and slowed me way down, I needed to drop 2 gears but I was able to regain my original speeds rather quickly.
#103
Yup, has the tow haul. I always use it. It dropped 1 gear, and then I was trying to keep it there. Every oncce in a while it would drop again and hit around 5000 RPM, which I didn't want, so I backed off, which probably didn't help. Even counting that mountain, we got just shy of 14 mpg towing, and 19 empth.
#104
1999 Chevy 1-ton dually 4x4, 454, crew cab with a short bed. We added a 50 gallon fuel cell in the bed to increase our range.
Sorry, couldn't find a good picture of just the truck. Guess I need to take some.
I'm gonna need a bigger bank account!!! Carolina Powerboat Association's Most Popular Docking Attendant |
#105
:D Hey John somebody cut off part of your Truck:D
