  #61
Old 01-14-2011, 05:34 PM
MMarsha's Avatar
MMarsha MMarsha is offline
Mr 2 chits
Gate was leaning- didn't set good enough with the freezing temps. It is not concreted in, too hard to move when that is done.
That red dirt/clay stuff is "bank run". Already thinking need blue stone going out to the gate- bank run is nasty stuff and gets red dirt all over every thing when I get out to unlock the gate.
Living room!
  #62
Old 01-14-2011, 09:55 PM
36outlaw's Avatar
36outlaw 36outlaw is offline
looking good mark....... i see the kerosene heater in the floor do you have plans for any other type heat?
Jeff
36 Outlaw "Royal Fare"
F350 Powerstroke w/ Banks
Riverfronthandyman.com
  #63
Old 01-14-2011, 10:12 PM
MMarsha's Avatar
Mr 2 chits
Yes, waiting for Spring for electric, once that is done then looking at insulation and heating options.
Lot of unanswered questions on what to do with the barn- may do some living space on the left side which is why the one side has the porch and so many windows or may do living space on 2nd floor which is why it was built the way it was with 2nd floor support. Then again, if ever built a house down there it is kind of overkill to have so much money wrapped up in a "barn".
Propane- quick warm up like standing by a fire
Kero/diesel- warms building but have to run generator, either the Honda or the Briggs (back right of red jet flame). Honda is a lot quieter but it is not on wheels and I'm kind of lazy. I use kero since it cleans burner and doesn't stink. I run this when down there for a few hours vs just stopping by.
  #64
Old 01-18-2011, 11:57 PM
CBlakeNS's Avatar
CBlakeNS CBlakeNS is offline
Very nice
Blake
  #65
Old 01-29-2011, 12:53 PM
MMarsha's Avatar
Mr 2 chits
I still winterized my boat, good call!
Here is a bucks eye view- my security team!
I'm skeered of heights so pic was kind of shakey.
  #66
Old 01-29-2011, 12:56 PM
MMarsha's Avatar
Mr 2 chits
clarify the temp reading, the 34 is current temp in barn and 15 is the recall temp (how cold it has been). Little confusing since it says "inside" and "outside" but I was on recall when I snapped the pic.
15 inside- need insulation and heat and so on but good for now.
  #67
Old 01-29-2011, 01:36 PM
PURPLE HORNET's Avatar
PURPLE HORNET PURPLE HORNET is offline
Shop looks good Mark, you better stop putting crap in their if your going to insulate. Just remember all that stuff has to be moved to insulate
GREAT BALLS OF FIRE !!!
  #68
Old 01-29-2011, 05:36 PM
36outlaw's Avatar
its filling up quick Mark.....................finished grading today.....pouring concrete on monday on mine!!
Jeff
  #69
Old 01-30-2011, 05:18 PM
MMarsha's Avatar
Mr 2 chits
Yea, I've been thinking about that...
It looks fuller than it really is and a lot of the stuff is an easy move. Move the tractors, 4 wheelers, boat and few other things out, move stuff in to the middle and insulate. I didn't put the big shelves against the wall so could insulate behind them, didn't want too much weight on the edge of new concrete, allows me to walk behind them to get access to things and so on.
Good point though- I hate doing double work and would have been nice to insulate before moving any thing in.
Jeff- are you cutting relief joints? We did, and dust was all over the place! We concreted after the barn was up so dealt with "inside rain" while the concrete cured. That was kind of a PITA.
  #70
Old 01-30-2011, 07:05 PM
36outlaw's Avatar
yes on the relief joints........... concrete is going to crack so when you saw it you give it a place to crack where you want it to.
Jeff
  #71
Old 02-17-2011, 07:10 PM
t500hps t500hps is offline
Originally Posted by MarylandMark View Post
Yes- they are staggered.
They claim the boards are stronger since there are several grains supporting the weight vs one grain in a single board. Cheaper as well.
Conestoga Buildings- http://www.cbstructuresinc.com/
Amish guys- they spend every night with their wife. 3 hour ride to work, work, and then 3 hour ride home.
WHAT....I never paid alot of attention to this thread but these are the people I'm considering using for my building. Would you recommend them again, any issues?
  #72
Old 02-17-2011, 07:18 PM
MIKES280's Avatar
MIKES280 MIKES280 is offline
Super Moderator
heres another onehttp://forums.boatfreaks.org/showthread.php?t=17346
I'll keep my Freedom, Guns and Money... you can keep the Change.
  #73
Old 02-17-2011, 07:21 PM
MMarsha's Avatar
Mr 2 chits
YES!! Very good work ethic. All I expect is one to do what they said they are going to do within the time line they say at the price they say. They did all of this, with some challenging weather at times on top of that.
Very few issues:
1- side door was dented which made the frame not line up. They pointed it out, installed it for the time being while they ordered another one. Once it showed up, they came back and installed it on my schedule.
2- shudders were the wrong size, too small. They ordered the correct ones, installed them when they did the door.
If I had a complaint, it would be the little metal scraps laying around from when they cut/trimmed. They did all the cutting/trimming in one spot so I know where to be careful at but still. Those shavings are pretty sharp and a PITA. I'd say I could fill a 5 gallon bucket once, not a ton and not sure the fix action either. Just saying and really if that is the only complaint, not bad!
  #74
Old 08-03-2011, 08:15 AM
MMarsha's Avatar
Mr 2 chits
Electric....
$2500 for service install, buried wire from transformer to barn.
$1000 for panel install, permits, 1 light and 1 switch (per code), inspections
$500 wire, panel, stuff
  #75
Old 08-03-2011, 08:46 AM
R'Addiction's Avatar
R'Addiction R'Addiction is offline
Small world. My wife and mother in law are going out to show houses to a guy that works for CB Structers. We are looking into getting a building built. Looks like they do nice work.
Fatti I cazzi tuoi !
