Go Back   Boatfreaks > General Forums > Boatfreaks On-Road
  #1
Old 04-06-2019, 03:00 AM
ShopSurfer's Avatar
ShopSurfer ShopSurfer is offline
'03 Silverado SS - Build/Fab
Was contacted by a fellow looking for some extra scoot under his boot. Told him, Yes, i can fix that.
2003 Silverado SS. All Wheel Drive - 1/2 ton pickup - extended cab. LQ9 6.0 liter LS. Truck was basically stock when i got my hands on it, had longtube headers, full exhaust, lowered and a very cool blue candy paint job. Pics dont show the color of the paint flop.
When it got here it was a filthy heifer, gave it a wipe down and took a few pics before i started ripping it apart.
2003 Sunsation 288 496
1992 Mustang - Turbo LS
1981 C10 - LS / Air Ride (current build)
The Following User likes ShopSurfer Post:
  #2
Old 04-06-2019, 06:05 AM
Rattlesnake Jake's Avatar
Rattlesnake Jake Rattlesnake Jake is online now
BANNED
Keep us posted on upgrades..
A country that removes history, will have no future...
"Now I'm getting old don't wear underwear, don't go to church and I don't cut my hair"
Growing Old is Mandatory, Growing up is optional...
The Following User likes Rattlesnake Jake Post:
  #3
Old 04-06-2019, 09:46 AM
ShopSurfer's Avatar
Disassembling the front end (mostly) Harness is on the to do list as well. Relocating the battery, ecu, fuse box and anything else that is a necessity. Wants to keep heat and A/C so once its all ironed out ill have to fit heater hoses and get some A/C hoses/lines made. Im guessing the truck was bagged at some point in its life or was going to be but makes my job easier!
  #4
Old 04-06-2019, 10:07 AM
ShopSurfer's Avatar
Fast forward past the boring chit like removing clutch fan, fan shroud, all of the heater/coolant hoses, a/c lines, headers/exhaust, intake... disconnecting the harness, dismount fuse block and ecu and shoved it aside..
yum, 16+ years of grime
better
uhh, thats not a radiator
test fitting where the intercooler is going to live
I would go up to the grill with it, if the outlet was pointing straight down, but the outlet is a 90* on the bottom tank....
The Following 4 Users Like ShopSurfer Post:
  #5
Old 04-06-2019, 10:24 AM
ShopSurfer's Avatar
making a 2.25" pipe merge into a 2"x3" square tube, which clears the ports on the divided t4 flange ports with a little assistance from a torch and hammer. Tacke my piping from the manifold to the t4 merge. melted it all together and call this side good for now. Still need to add a 1.75" tube for the runner up to the external wastegate.
The Following 2 Users Like ShopSurfer Post:
  #6
Old 04-06-2019, 11:06 AM
Sutphen30's Avatar
Sutphen30 Sutphen30 is offline
Charter Member
tight fit,looking good
I like my food with ketchup.
The Following User likes Sutphen30 Post:
  #7
Old 04-06-2019, 11:22 AM
ShopSurfer's Avatar
onto the other side... same routine. make the merge, plumb in between, melt together
  #8
Old 04-06-2019, 11:44 AM
ShopSurfer's Avatar
these pictures got the guy pretty stoked. lots of things i would do different if it were mine but to each their own. i think the symmetrical/mirrored look turned out well. not an easy task when trying to mirror something that isnt a mirror image. nelson racing is the only company i know of that sells mirror image compressor housings. but im happy with the progress
keep in mind, with the turbos facing each other, the housings are larger/smaller on either side with the turbine housing having the inlets where the flanges mate on opposite sides as well. so the bulk of the housings make them seem crooked but my OCD laser aligned, triple measured everything haha. it bugged the chit outta me
The Following 3 Users Like ShopSurfer Post:
  #9
Old 04-06-2019, 11:45 AM
ShopSurfer's Avatar
thats all i got for now, ill post more after i get it wrapped up!
  #10
Old 04-06-2019, 12:47 PM
Hook'em's Avatar
Hook'em Hook'em is online now
Wow, that's kewl chit bro. You and your skills are beyond impressive. I can't wait to see this beast. Awesome.
去他妈的自己
Badges? We Don't Need No Stinkin Badges
The Following User likes Hook'em Post:
  #11
Old 04-07-2019, 06:26 AM
BANNED
Gotta ask, is that a Stock engine??
Awesome work BTW.
  #12
Old 04-07-2019, 09:50 AM
Sutphen30's Avatar
Charter Member
very nice
what size turbos are those?
  #13
Old 04-07-2019, 09:59 AM
ShopSurfer's Avatar
Originally Posted by Rattlesnake Jake View Post
Gotta ask, is that a Stock engine?? Awesome work BTW.
Yes it is. Gen 3 LQ9 6.0. 100% stock longblock as of now. I really dont understand his tactics as far as prioritizing the parts needed. Tho i am sure the engine will outlast the transmission, transfer case, cv axles etc etc.
And thanks everyone for the kind words. I appreciate it!
  #14
Old 04-07-2019, 10:11 AM
ShopSurfer's Avatar
Originally Posted by Sutphen30 View Post
very nice
Too damn big. They wouldn't even be on my list of suggestions.
Intake Inlet/ Outlet 3.75" / 2.25"
Compressor A/R 0.66
Compressor Inducer /Exducer (MM) 68.70 / 97.80
Compressor Trim 69
Flange T4 4-Bolt
Turbine A/R 1.05
Turbine Inducer / Exducer (mm) 87.40 / 77.00
Turbine Trim 92
  #15
Old 04-07-2019, 10:37 AM
Sutphen30's Avatar
Charter Member
turbos seem a little big,,maybe he's planning on a stroker w/ more camshaft.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
