  #61
Old 10-09-2009, 11:24 AM
waterboy waterboy is offline
See post #244.
Monroe is about 11K acres, near bloomington. It's OK for a smaller lake.
WATERBOY
  #62
Old 10-09-2009, 03:27 PM
AssEnd's Avatar
AssEnd AssEnd is offline
Originally Posted by AIR*TIME View Post
did you get it done, what speeds are you getting 78, if you can't break 80 you need a 2'' shortie and hyd steering full from dash to transom add on helps but you might have chinewalk.
Well went out for a spin, Ran 68 on GPS at 5100 RPM with full tank of fuel 400L or 100US gallons and two 200 pound adults. Tested it with a 4 blade 24pitch.... I am thinking a 25pitch mirage plus 3 blade would wake it up a bit..?
  #63
Old 10-10-2009, 07:29 PM
bajabob 600's Avatar
bajabob 600 bajabob 600 is offline
assend i have a 540dart i got 85mph at 55000rpm mirage 3 blade the way to go it the best for the baja
  #64
Old 10-11-2009, 09:49 AM
AssEnd's Avatar
Thanks for your input BajaBob. I've heard that Mirage 3 blades are the way to go, apparently more bow lift..
Hopefully enough time this season to test one out.
  #65
Old 10-11-2009, 09:55 AM
AssEnd's Avatar
Originally Posted by AssEnd View Post
Haven't propped it yet. using a 24 bravo 4 blade.. Double R Performance had it up to 72mph with that prop.
Double R performance are by far the best in Canada.... I would recommend them to anyone..
  #66
Old 11-08-2009, 12:28 AM
Pat Bates's Avatar
Pat Bates Pat Bates is offline
First post. Great site! This will make it easier to get through winter.
'92 270 with a 502, slightly upgraded....
File Type: jpg Chicago Loop Cruise '09 017 (Medium).jpg (81.1 KB, 118 views)
File Type: jpg CrownieHQ Rally Table Rock 2009 014 (Medium).jpg (69.5 KB, 119 views)
File Type: jpg CrownieHQ Rally Table Rock 2009 008 (Medium).jpg (128.7 KB, 117 views)
  #67
Old 11-08-2009, 11:07 AM
Nice motor! Tell us about it.
WATERBOY
  #68
Old 11-08-2009, 10:15 PM
Pat Bates's Avatar
Not really sure to tell you the truth. I bought the boat this way from Shogren. Supposedly it has all the good internals, Edelbrock Air Gap manifold, Lightning headers, Holley 850 cfm carb, MSD ignition, rev limiter set at 5600 rpm.
A good friend of mine who sells Nordic and builds his own motors in TX (Full Throttle Marine) thinks its getting about 570hp to the propshaft after he checked it out at Table Rock. I guess I need to get the motor dyno'ed, but I'm happy with it.
Honestly I've scared the chit out of myself. It's a scary ride at 75mph, and I've got a few hundred rpm to go before I hit the rev limiter. Crazy chinewalk. I need to spend some money and get hydraulic steering on it. Current job situation prevents that. Here's a short video showing the chinewalk issue....
http://www.youtube.com/watch?v=CeJkJf_kwi0
I still love the boat. It's a head turner just for it's rumble, and you wouldn't know it's a '92 by looking at it. I baby it.
  #69
Old 11-09-2009, 08:35 AM
AssEnd's Avatar
I am pretty sure you should have the BLUE msd box not the red as it is for automotive application and doesn't have the same marine seal to ward against moisture.. I am not 100% sure but you might want to look into it.
A used one from Double R Performance would be fairly inexpencive and would be plug and play......
Nice looking engine though..
  #70
Old 11-09-2009, 08:37 AM
AssEnd's Avatar
I recently had my 515ci built. only one valve cover has a breather on it and oil somehow makes it through the end of the hose going to the carb.. have you had any issues with oil coming out of your valve cover breathers..?
if not maybe you could send me some info on your set up...
thanks
  #71
Old 11-09-2009, 01:31 PM
Pat Bates's Avatar
thanks
No, I have not had any problems with oil coming out of the breathers.
My issues have been my own stupidity. Forgot the drain plug and half submerged the motor one time. I had to replace the cap, rotor, plugs and plug wires in order to getting running good again. Damn, I was mad!
I wish I had more info on my set up. I bought it this way from Shogren Marine and they didn't have any info from the previous owner (from Iowa....anyone recognize it?) It would have to be torn down to know what's exactly in it. I know it has an aggressive cam in it, and all the internals were upgraded from factory. The block is the only original part, that I am know of.
  #72
Old 12-07-2009, 08:16 PM
hay pat my boat chine walk like yours i put longer trim tabs and i run a mirage prop not a plus . the plus makes my bow to high .wt prop are you runnig??
  #73
Old 12-10-2010, 07:37 AM
Dead Silence's Avatar
Dead Silence Dead Silence is offline
96 272, had a 454 Mag in it, building a 540 for next summer. Love the boat, fits our lake, life style, perfectly. Big enough to play on big water, bay etc, small enough to be your everyday boat.
If you think Education is expensive........ try Ignorance!!!!
  #74
Old 12-10-2010, 07:53 AM
couple more
  #75
Old 12-10-2010, 08:55 AM
Blue Oval's Avatar
Blue Oval Blue Oval is online now
Great pic of dog sleeping!
Captain Bob's Boating Club(President)A drinking group with a boating problem!
