  #46
Old 12-07-2011, 07:13 PM
MMarsha's Avatar
MMarsha MMarsha is offline
Mr 2 chits
Originally Posted by cloke View Post
What a great project.
Congratulations !!!!
Hi Alec!! Hope all is well!!
  #47
Old 12-07-2011, 09:39 PM
cloke's Avatar
cloke cloke is offline
ALL GOOD pal.
  #48
Old 12-09-2011, 09:03 PM
Panther's Avatar
Panther Panther is offline
Fancy seeing you here Alec.
Frank
Geronimo!!
"FUMarine, LLC"
"CMI Staffing"
  #49
Old 12-10-2011, 12:43 AM
cloke's Avatar
Frank
Hi Frank.
I heard of this project and came to take a look.
Beautiful job.
I appreciate the effort it took to fit in with the original house.
Kudos
  #50
Old 12-10-2011, 10:06 AM
MIKES280's Avatar
MIKES280 MIKES280 is offline
Super Moderator
Hi Frank.
Beautiful job.
Kudos
well don't be a stranger come back soon. We try to keep some of the drama down and just have fun
I'll keep my Freedom, Guns and Money... you can keep the Change.
  #51
Old 12-10-2011, 12:49 PM
Panther's Avatar
Exactly!
And we try to derail each thread... For instance, we talk about drywall in cylinder head threads and broken velocity's in engine rebuild threads!
Geronimo!!
"FUMarine, LLC"
"CMI Staffing"
  #52
Old 12-11-2011, 08:53 AM
offshoredrillin's Avatar
offshoredrillin offshoredrillin is offline
Nice Russ...but where are the pics of Faith workin in the buff :D
  #53
Old 12-11-2011, 09:22 AM
t500hps t500hps is offline
Hey, those have absolutely nothing to do with building a garage........but neither do the last 10 posts
  #54
Old 12-11-2011, 12:18 PM
MMarsha's Avatar
Mr 2 chits
Exactly!
  #55
Old 12-11-2011, 07:51 PM
Panther's Avatar
Looks like the thread is on track!
Geronimo!!
"FUMarine, LLC"
"CMI Staffing"
  #56
Old 12-11-2011, 07:54 PM
Panther's Avatar
Lookin back at this thread from the beginning, I really wish I could build one of these at my new pad.
Geronimo!!
"FUMarine, LLC"
"CMI Staffing"
  #57
Old 01-23-2012, 10:26 PM
OK.......more progress and it took hiring another builder to finish the last couple steps. Other parts I've done myself.
The original builder put up that huge scaffolding so that the ceiling (corrugated metal) could be installed. Unfortunately he disappeared so I hired another builder to come install the ceiling and build the steps (I had intended to build them myself but decided against it).
Before the ceiling went in I found a company to insulate the walls for what I could buy the materials for. R-19 went in the I had some buddies come help me put Tyek wrap on backwards to cover all the walls.
The lights are 6 bulb T-5 fixtures that put out ALOT of light. The lighting company used a rating for commercial and said to use 6 fixtures......so I bought 8!!! I ended up cutting holes to recess them after framing them out. I used sheet metal so the blown in insulation wouldn't rest against the back of the fixtures.
The 3rd pic is taken from the staircase landing:
  #58
Old 01-23-2012, 10:28 PM
We had decided to add attic space which then created the need for a staircase. After insulation went in I floor the entire space upstairs. It's 14 x 56 long and is prepped for plumbing, cable TV, electric. I called it a big attic and my wife is already telling me to "finish" it off as a party room....guess she has some money stashed somewhere I don't know about!!!
Notice the exterior door sitting there. Since I've insulated the entire thing I have to do something about the big hole that air escapes upstairs through. I've bought the materials to frame, insulate, and door the top of the staircase to seal the 2 areas off from each other.
I also found the framers really screwed up. Apparently as they were setting the trusses on 24in centers, one guy on one side measured 23 inches for one of the spans.......the damn thing is crooked and the plywood doesn't fiit the trusses like it should........all the way down the building!!!! Required shaving sheets repeatedly til I got to the end of the building.
  #59
Old 01-23-2012, 10:32 PM
The sewage basin is set just below the staircase landing with the waterlines ready for a hot water heater, etc.
  #60
Old 01-23-2012, 10:35 PM
The shed on the rear is nearly un-changed. I have cut 3 blocks out to install foundation vents and bolted a top plate to build up but that's it......pics to come once the weather breaks and I get started on it.
