#16
from the pics it looks like you are running merc sportmaster lowers if so have you thought about triming the skags everything i here they are 3 to 4 mph slower until you trim them and sharpen them up like a bravo skag stock they are about 2 inches longer
I'll keep my Freedom, Guns and Money... you can keep the Change. |
#17
These are 1" shorties, didn't know about trimming them up. Thanks Mike
GOOD GOGGLY BOOGLY MOOGLY MAN! PUT THE WIGGLIN PIN BACK IN THE WOBBELIN HOLE! WERE SINKEN FAST! |
#18
ok but the skags on the merc shortes are much longer then the imco or the standerd bravo. go look at a bravo and then look at yours the sportmaster gear case is longer and on a cat that would be a goood thing but you should not need it on a v
#19
I will check it out, would you try to get the skags on the sm the same as the imco and bravo?
#20
WOW! what does a swap of engines and drives like this cost? I was at the last APBA offshore races in Cleveland, Ohio and watched Bob Teague switch the drives on Liquid Mettle. After I wiped the drool off of my chin(washed my hands) then shook his hand and he told me $100k per side plus fans (my slang for props).
