Go Back   Boatfreaks > General Forums > Speed on the Water
  #1
Old 10-09-2023, 11:19 AM
Jason Johnson Jason Johnson is offline
Contributor
Princeton Electric Speedboating Team Eyeing APBA Kilo Run Record In Big Bird
The electric speed record race continues later this month with the student-led Princeton Electric Speedboating's APBA-sanctioned kilo run in North Carolina.
https://www.speedonthewater.com/prin...rd-in-big-bird
The Following User likes Jason Johnson Post:
  #2
Old 10-10-2023, 07:21 AM
Apollard's Avatar
Apollard Apollard is offline
Interesting project, but it illustrates the problem for heavy duty electric vehicles. 24 kwh battery weighs as much as 75 gals of gas (~350 kg), but gives the 200 hp motor a 10 minute run time. And that assumes discharging to zero (horrible for battery packs)with zero losses in the A/C conversion.
75 gal of gas runs a WOT 200hp engine a long time
The math, again all at 100% efficiency
200 hp = 149 kw
24 kwh / 149 kw = 0.16 hours, or 9.66 minutes
Basically, one, maybe two speed runs per charge
"Just because some people cannot be trusted with liberty does not mean other people can be trusted with power."
Copyright ©2000 - 2025, vBulletin Solutions Inc.
